The twin-turbo Z rear upright is forged aluminum, which shaves 7 lbs of unsprung weight. Combined with the larger brakes, the whole unsprung assembly comes out only 2 lbs heavier than stock despite a massive increase in braking power and heat capacity. Note the different mounting point for the rear shock, however (lower left on each upright).
Sem strojar, mam chut to vyzkouset, ale neni mi jasny jak je to udelany s tlumicem a co vsechno je jeste potreba udelat. Zminuji se o tom v tom textu, ale na to je moje AJ kratka. Pokud nekdo vi vic, rad se priucim....
