K:koupím turbo t25 na ca18det
koupím turbo T25 nebo T28 na CA18DET jen velmi dobrý stav díky.Tel: 774918731
Re: K:koupím turbo t25 na ca18det
turbo T25G
///T25G ma AR .80 kompresoru a AR .64 Turbíny
The T25G is the next generation T25 that came out on the SR20DET S13 cars.
The only difference is a larger Exhaust housing and fins allowing slightly more boost to be held at top end with a lil less inlet temps.
If you can pick 1 up cheap, go for it! its a quick easy upgrade, but still wont be to fantastic over 15psi just like the normal T25.
On a standard DET with stock ECU, injectors etc, this turbo will be enough to net you around 230-250bhp@14psi ///
co tím chtěl básník říct?Fizzbiker píše:turbo T25G
tim chce nejspis rict ze ma T25G turbo a popisek ti tam tal aby jsi vedel co to je zac.....neni primo z CA..
exatly... nabizim tohle turbo je to takovej "hybrid" t25ky a t28čky...
